Toyota Tercel Oil Use and Fouled Plugs
RJWS
its a early 90's tercel, around 92 or 94, its a friends car...it often needs oil and needs a change of spark plugs every 3-4 months ... the oil I think might be a leak from somewhere if its using that much but maybe someone has a better idea. and the spark plug problem i have no clue! thank you!
Sep 8, 2007 at 3:53 AM
  • 75,988 POSTS
[quote:6ef94b329f="rjws"]its a early 90's tercel, around 92 or 94, its a friends car...it often needs oil and needs a change of spark plugs every 3-4 months ... the oil I think might be a leak from somewhere if its using that much but maybe someone has a better idea. and the spark plug problem i have no clue! thank you![/quote:6ef94b329f]
With no physical leakage its leaking into the combustion chamber-could be bad valves/seals/rings/ Time to overhaul the engine or a long block
Sep 8, 2007 at 7:49 AM
RJWS
[quote:710b333385="rasmataz"][quote:710b333385="rjws"]its a early 90's tercel, around 92 or 94, its a friends car...it often needs oil and needs a change of spark plugs every 3-4 months ... the oil I think might be a leak from somewhere if its using that much but maybe someone has a better idea. and the spark plug problem i have no clue! thank you![/quote:710b333385]
With no physical leakage its leaking into the combustion chamber-could be bad valves/seals/rings/ Time to overhaul the engine or a long block[/quote:710b333385]
But in this case wouldnt I then see smoke coming out the exhaust because i wont be burning all the oil during combustion??? this would likely solve the spark plug problem. oil in the combustion chamber...
Sep 8, 2007 at 8:15 AM
  • 75,988 POSTS
[quote:af9bb96c04="rjws"][quote:af9bb96c04="rasmataz"][quote:af9bb96c04="rjws"]its a early 90's tercel, around 92 or 94, its a friends car...it often needs oil and needs a change of spark plugs every 3-4 months ... the oil I think might be a leak from somewhere if its using that much but maybe someone has a better idea. and the spark plug problem i have no clue! thank you![/quote:af9bb96c04]
With no physical leakage its leaking into the combustion chamber-could be bad valves/seals/rings/ Time to overhaul the engine or a long block[/quote:af9bb96c04]
But in this case wouldnt I then see smoke coming out the exhaust because i wont be burning all the oil during combustion??? this would likely solve the spark plug problem. oil in the combustion chamber...[/quote:af9bb96c04]
The matter here is the sparkplug being coated with oil and it don't go there. No blue smoke than you have an actual leakage somewhere-and again oil on the plug will burn and will come out of the exhaust as blue smoke.
Sep 8, 2007 at 8:50 AM
Suggested Repair
Inspect for an external oil leak. If none is found and the spark plugs are oil-fouled, oil is entering the combustion chamber from worn valve seals, valves, or rings; overhaul the engine or install a long block. Blue exhaust smoke supports internal oil burning.
Conversation Summary
The owner of an early-1990s Toyota Tercel reports frequent oil use and spark plugs that need replacement every 3-4 months. The expert says oil-coated plugs indicate oil reaching the combustion chamber from bad valves, seals, or rings, requiring an engine overhaul or long block. If there is no blue exhaust smoke, an external leak should be investigated because burned oil typically exits as blue smoke.
