tercel air conditioning
TOYOTA TERCEL
MGYOCKEY
95 Toyota Tercel, 334K miles, 4 cyl - A/C works for 10 minutes then gradually blows warmer air. Vent temperatures increase from 54 degF to over 80. Low pressure side = 45 psi, high = 225 psi. When the engine is really warm, I can see the pressures changing somewhat (which I think means that the expansion valve is working). Compressor never cycles but stays on constantly. I would love suggestions on how to pinpoint the problem. Thanks in advance.
Jul 10, 2007 at 3:55 PM
DANKLIBRA
  • 7 POSTS
DID YOU CHECK THE BLOWER MOTOR? UNDERNEATH YOUR DASH ON THE PASSENGER SIDE TO THE VERY RIGHT OF GLOVE BOX IN BACK RIGHT CORNER? MINE GOT STUCK AND I LIGHTLY TAP IT AND IT WOULD CLICK ON. IT TURNS OUT I NEED A NEW ONE BUT DURING THE SUMMERS IN AZ WHEN YOU DON'T HAVE ANY MONEY I DIDNT MIND TAPPING IT TO KICK IT IN GEAR. HOWEVER EVERYTIME I TURNED THE CAR OFF I WOULD HAVE TO DO IT ALL OVER AGAIN. ANYWAYS WHEN IT WASNT WORKING THE AIR BLOWING OUT WAS SO WARM. EVENTUALLY I TAPPED IT ALL OUT, SO I WOULD USE A WATER BOTTLE OR SOMETHING TALL ENOUGH TO REACH THE CENTER OF THE MOTOR AND HOLD IT UP UNTIL IT WOULD START WORKING. I'M NOT RECCOMMENDING THESE FIXES; IM ONLY TELLING YOU WHAT HAPPEND TO ME SO MAYBE YOU COULD TROUBLE SHOOT THAT AREA. TRUST ME I KNOW I SHOULD HAVE JUST BOUGHT A NEW ONE :)
Nov 24, 2007 at 4:50 AM
