When making sharp right turns in my '93 tercel I noticed a sort of grinding/clunking sound. When I took the car to a mechanic he informed me that I needed a new cv joint and axel, yet I have read when catching this problem in time, this replacement is unneeded. The car has about 40,000 miles, should I seek further opinions?
1993 Toyota Tercel CV Joint Clunk
When making sharp right turns in my '93 tercel I noticed a sort of grinding/clunking sound. When I took the car to a mechanic he informed me that I needed a new cv joint and axel, yet I have read when catching this problem in time, this replacement is unneeded. The car has about 40,000 miles, should I seek further opinions?[/quote:70418b8ac4]
Depends on the damage to the CV joint ball bearings. Generally, the CV boot cracks or is torn by an impact (rock, curb), the grease leaks out and water, dirt wears out the bearings. If allowed to continue it will damage the bearings and housing. You can replace the boot, but I have found it much simpler to replace the axle with a reman'd unit.
Check the CV joint on the other side (boots) while you're at it.
Suggested Repair
Inspect the CV joint for boot damage, lost grease, and worn ball bearings or housing. A torn boot can sometimes be replaced if caught early, but a remanufactured axle is often simpler once the joint is damaged. Also check the CV boots on the other side.
Conversation Summary
The owner of a 1993 Toyota Tercel with about 40,000 miles hears grinding or clunking during sharp right turns. A mechanic recommended a new CV joint and axle, and the owner asked whether an early repair could avoid replacement. The expert explained that a cracked or torn boot lets grease escape and dirt enter, wearing the bearings and housing. Replacing only the boot is possible, but replacing the axle with a remanufactured unit is often simpler; the other side's boots should also be checked.
