94 Tercel
PRANEEDH
  • 5 POSTS
I changed oil few days before and filled over the full line.
Few days later the engine ligts show and and display check engine.
I replaced the distributor/ Cap and wires. Still the engine light is on.
I hae planed to replace the Plugs as the next step.
What else should I look or change?
How to get rid of this "Check engine" light?
Jul 14, 2007 at 8:42 AM
  • 75,988 POSTS
[quote:d53278484f="praneedh"]I changed oil few days before and filled over the full line.
How to get rid of this "Check engine" light?[/quote:d53278484f]
Remove the EFI and Stop fuses-give it 30secs then replace it. Now start vehicle if its there again, its time to pull the code/s and ID the problem area/circuitry.
HTH/Good Luck!
Jul 14, 2007 at 3:43 PM
DANKLIBRA
  • 7 POSTS
from my experience I just disconnect the battery for about 10-15 minutes. After reconnect the lights stay off; and based on TEMPE TOYOTA if the lights come back on after this then there truly is a problem; if the lights stay off its fine.
Nov 17, 2007 at 11:05 PM
