2003 Toyota Tercel timing belt replacemente
156,000 MILES • 4 CYL • 2WD • MANUAL
ANTONIO888
Hello, I have just change the timing kit to my car but two or three days after sudenly the power of the engine fall dawn. Checking it, we found that the spark plugs were wet and corbonized. I replaced them but four day after ther were damaged again. It is possible that the changes and setting of the time belt could cause the problem with the spark plugs or it was just bad luck.
Cheers
Mar 16, 2009 at 4:52 AM
BMRFIXIT
  • 19,053 POSTS
You had no issue before the timing belt was replaced !
work done have to be recheck make sure you have set the timing correct and if all line up
check coil and ignition wires
need ttiming marks let me know
Mar 25, 2009 at 10:38 PM
