1999 Toyota Tercel Timing Belt & Water Pump
111,200 MILES • 4 CYL • FWD • AUTOMATIC
PETER_H
I just bought a 99 Tercel CE, auto, 4cyl, 1.5 Eng with 111,200km. the car was hardly driven over the last 3 years, previous owner bought it at 93,000km in 2006. It has been well kept, & maintained except the Water pump and Timing Belt has not been done. How soon should I consider doing this job and is there any other major maintainance I should do at this time.
Jun 18, 2009 at 1:02 PM
BMRFIXIT
  • 19,053 POSTS
Need to be done soon {timing belt and pump }
inspect and replace belts
check hoses
check tranny fluid and replace
check brakes and brake lines
check air filter
rotate tires
good luck
Jun 18, 2009 at 2:55 PM
