1998 Toyota Tercel Self starting problem
1998 TOYOTA TERCEL
MALAM161
1998 Toyota Tercel Two Wheel Drive
I have Problem with start-up. When I switch on my Key all the dash board lights become on but no respond on the self starter. It was not giving any response , It was complete dead. Then i switch on my headlight and found Battery also full charge. Then I engage my car in Gear and switch the Key to start without pressing the clutch and my car moved little due to the Gear. After I make it Neutral and started the car normally and the self starter took around 15 Seconds and it all the time 15 seconds Self starter was rotating and Engine become started. Could you teel me the Exact problem.
Sep 7, 2010 at 10:47 AM
Chek and test the starter relay
Sep 8, 2010 at 5:19 AM
