1998 Toyota Tercel
1998 TOYOTA TERCEL
EDCRO8
1998 Toyota Tercel 4 cyl Front Wheel Drive Automatic
When I start up the engine, a knock noice is hear
for a few secs. and then runs normal.
The engine was rebuilt. 5E-FE
Oct 28, 2009 at 5:44 AM
  • 31,937 POSTS
Hi there,
I would be replacing the oil filter first, you may have one that is draining oil back into the sump, some better quality filters have a check valve to stop this, also was the oil pump replaced with the engine re build, and you should get an oil pressure test done just to make sure all is ok.
mark (mhpautos)
Oct 28, 2009 at 9:57 AM
