1997 Toyota Tercel WONT START
10,000 MILES • 4 CYL • 2WD • MANUAL
JWQ.671
HI, TERCEL WONT START HAVE CHANGED PLUGS IGNITER COIL AND STARTER? PLEASE HEL[
Oct 15, 2008 at 10:09 PM
BMRFIXIT
  • 19,053 POSTS
Do you have spark did you check for fuel
check fuses and relays
check timing and fuel pump
Oct 15, 2008 at 10:17 PM
JWQ.671
fuel good, pump replaced and fuses ok
Oct 15, 2008 at 10:25 PM
BMRFIXIT
  • 19,053 POSTS
check timing and spark
Oct 15, 2008 at 10:29 PM
JWQ.671
not sparking, timing on.
Oct 15, 2008 at 10:45 PM
BMRFIXIT
  • 19,053 POSTS
Timing belt is OK ?
remove distributor cap and check rotor if turning while cranking
scan for codes
turn ignition key on do you have check engine light on
you should if not recheck fuses and relays
do u have an alarm system that may effect the system ??
check for battery power at the coil with key on
Oct 15, 2008 at 11:04 PM
