1997 Toyota Tercel WONT START
Engine Mechanical problem
1997 Toyota Tercel 4 cyl Two Wheel Drive Manual 100.00 miles
GOOD MORNING, MY TERCEL HAS NOT STARTED IN 2 MONTHS, HAVE CHANGE BATRY,STARTER,IGN/COIL/PLUGS/ALTN/IGNATOR/CAM SENSOR/CRNK SENSOR.
NOT ABLE TO START... WHAT SHOULD I CHECK NEXT?
Sep 26, 2008 at 8:37 AM
  • 75,988 POSTS
Hafa Adai
Do below and tell me what's missing Fuel or Ignition then comeback
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors-
BTW do you hear the fuel pump come On for a few secs? When key at run position
Sep 26, 2008 at 9:17 AM
