1997 Toyota Tercel fuel pump
MSGINAH
  • 5 POSTS
Engine Mechanical problem
1997 Toyota Tercel 4 cyl Front Wheel Drive Automatic
i changed the fuel pump on my car, and my car still wont turn on.. it has spark but wont turn on..
Nov 19, 2009 at 9:35 AM
  • 75,988 POSTS
Do you hear the fuel pump come On when you turn key to run/on? If not do below
Find the check connector and jumper the Fp to Batt terminal and see if the fuel pump comes on
Nov 19, 2009 at 9:48 AM
MSGINAH
  • 5 POSTS
YES IT DOES..
Nov 19, 2009 at 10:24 AM
  • 75,988 POSTS
If you can hear the fuel pump come On when you turn the key On -check the fuel pressure to rule out the fuel pump.
Nov 19, 2009 at 10:27 AM
MSGINAH
  • 5 POSTS
IT HAS FUEL PRESSURE MY HAND HELD DIAGNOSTIC MACHINE SAYS ITS THE AIT?? I DONT EVEN KNOW WHERE THAT IS LOCATED
Nov 19, 2009 at 10:35 AM
  • 75,988 POSTS
The IAT will not prevent the engine from starting but will give you a driveablity problems
Nov 19, 2009 at 10:42 AM
MSGINAH
  • 5 POSTS
WELL I DONT KNOW WHAT ELSE TO0 CHECK.. I SPENT MONEY ON A NEW FUEL PUMP. AND NOW IT WONT TURN ON
Nov 19, 2009 at 10:45 AM
  • 75,988 POSTS
If you have fuel pressure check if the injectors are pulsing
Nov 20, 2009 at 4:56 AM
