1997 Toyota Tercel
19,900 MILES • 4 CYL • FWD • AUTOMATIC
JENNMILLAS
the car wont start it has a new starter and it makes no noise just a clicking noise when trying to be started, but i have power for the raido and lights
Jul 31, 2008 at 10:06 AM
  • 31,937 POSTS
HI there,
Check if the starter solenoid is getting power, thats the small wire attached to the starter, this should have power when you turn the key to start, if so and you have 12V at the main starter terminal, just check that the battery connections are clean and tight , if so you will have a faulty starter. Start here,
mark (mhpautos)
Jul 31, 2008 at 10:18 AM
