1996 Toyota Tercel strange engine stalling problem
186,000 MILES • 4 CYL • 2WD • AUTOMATIC
VANLAW
I bought this car recently and only discorvered the problem once I began driving it regularly. What happens is in the morning, and sometimes in the midday, my car will start okay but within a mile my car will stall when I come to a stop or slow. In detail, the car will drive fine until I come to a stop at a light or sign, the engine stalls and the battery light comes on. I can quickly turn the car back on, and after that I usually have no more problems for the whole drive. Somedays the car doesn't have this problem. The car drives great, but it does idle very very quietly. I'm thinking it's the IAC, but I can't be sure. Is this typically what a faulty IAC does?
Apr 28, 2009 at 12:17 PM
MMPRINCE4000
  • 8,548 POSTS
A reasonable conclusion.
Remove and clean the IAC. If equipped with EGR, remove it and clean also. This would be a good starting point.
Other possibilities are the TCC (Torque convertor clutch lockup solenoid, intermittent failure) or a possible ignition module.
Apr 29, 2009 at 8:54 AM
