1996 Toyota Tercel replaceing timing belt
MONEYLCLA
Engine Performance problem
1996 Toyota Tercel 4 cyl Front Wheel Drive Manual
how do u get the outside belt off to put a new inside belt on
Jul 3, 2009 at 10:31 AM
  • 75,988 POSTS
Why are you replacing the timing belt? If its broken or has jump timing-you need a repair manual to guide you through out the process-its not a simple job if you haven't done such a thing. Best leave it to the pros.
Jul 3, 2009 at 10:38 AM
