1996 Toyota Tercel Clutch fluid
RALLAN
1996 Toyota Tercel
Where do I find the clutch fluid reservoir? How do I check the clutch fluid, bleed it and add more?
updated 2-2-10
I just had an answer to part of my question. Is there anyway to ask the guy who responded "how do I check the fluid level, where do I find the reservoir?
Feb 1, 2010 at 3:20 AM
  • 75,988 POSTS
S1 Check the fluid level if low fill it to the Max.
Get a helper to pump the clutch
S2 Have helper step on the clutch slowly all the way in atleast 3X, you open up the bleed valve on the slave/servo till the fluid stops then close it. NOtE: you can use a palstic tube on the bleeder valve into a container with brake fluid in it-stop when there's no more bubbles then close the valve.
Do this atleast 3X if pressure is no good and there's not leak the clutch master cyl is leaking internally.
Feb 1, 2010 at 4:30 AM
