1996 Toyota Tercel check engine light flashing
1996 TOYOTA TERCEL
DMAMON12
Engine Performance problem
1996 Toyota Tercel 4 cyl Two Wheel Drive Automatic 285xxx miles
my tercel started to hesitate and the other night it died on me at a light when it restarted it was shaking and smelled bad and the check engine light was flashing> so i changed the plugs wires cleaned the throttle body and the o2 sensor > it starts fine but when i put it in drive it again shakes and feels like its gonna die> please help
May 26, 2009 at 5:52 PM
Scan the computer for OBD2 code/s this is your starting point on finding out what's happening in the engine management system that might be causing your problem. Autozone provides this service for free 99.
May 26, 2009 at 6:01 PM
DMAMON12
thank you very much for the info!
May 26, 2009 at 6:33 PM
BMX4LIFE
You coolent temp sensor is bad
Jun 6, 2009 at 6:30 AM
