1995 Toyota Tercel temp guage
18,900 MILES • 4 CYL • 2WD • AUTOMATIC
MIKE CRUZ
after a front end accident the temperature guage will not register but the the cooling fan works along with the heater working.
Where should I look for a remedy?
Thank you in advance
Dec 8, 2009 at 8:35 AM
  • 75,988 POSTS
Check and test the coolant temperaure sensor and if it has an engine temperature gauge switch check that too-to include the wiring connectors
Dec 8, 2009 at 8:56 AM
