1995 Toyota Tercel How to adjust 16 valve 1.5 L engine
1995 TOYOTA TERCEL
239,000 MILES • 4 CYL • 2WD • MANUAL
FATBOY33
Could you help me out with the procedure to adjust the valves on my 95 tercel. I have lost power and have noticed alot of clattering from my head.
May 1, 2010 at 4:39 AM
MMPRINCE4000
  • 8,548 POSTS
Toyota uses shims to adjust valve clearence, and you need a special tool to remove shims.
Remove valve cover and check clearence, .008 on intake and .010 on exhaust, on COLD engine.
Jul 5, 2010 at 2:29 AM
