1995 Toyota Tercel horn
1995 TOYOTA TERCEL
70,000 MILES • 4 CYL • FWD • AUTOMATIC
TROY MCCARTHY
Wondering the quickest way to get my horn working. The fuse and box are good but the end where it joins the horn is dead. Looks like a mess to rewire. Help
Aug 27, 2008 at 3:58 PM
SERVICE WRITER
  • 9,123 POSTS
IS the horn good if you put power directly to it?
You may be able to join them together fairly easy. The dealer may offer a pigtail to replace the connector. If so, You only need a few wire connectors.
Aug 27, 2008 at 6:47 PM
TROY MCCARTHY
finally took the button off the steering wheel, only to find the wire beneath had been cut .. Repaired wire and now works like a charm.
Aug 27, 2008 at 9:49 PM
