1995 Toyota Tercel gauges & rear lights
158,000 MILES • 4 CYL • FWD • AUTOMATIC
JGRACEOMA
I installed a new headlight and side light assembly on my son's car. They both work fine but now the dashboard doesn't light up at night and the rear lights also don't light up but everything else works fine? Any ideas?
Jan 5, 2008 at 4:01 AM
FISHERMAN
  • 937 POSTS
[quote:424541b2c8="jgraceoma"]Electrical problem
1995 Toyota Tercel 4 cyl Front Wheel Drive Automatic 158000 miles
I installed a new headlight and side light assembly on my son's car. They both work fine but now the dashboard doesn't light up at night and the rear lights also don't light up but everything else works fine? Any ideas?[/quote:424541b2c8]
Hello !!
Well start checking the fuses (one of them might be blown) if checked good then its time to review the wiring you worked on....
could be a "broken" wire that feeds the tail lights and the dashboard lights also.
check that and let us Know!
Good Luck!
Jan 5, 2008 at 4:14 AM
