1995 Toyota Tercel EGR valve diagnostic light is on
144,444 MILES • 4 CYL • 2WD • AUTOMATIC
ELTONDJ
The diagnostic codes for the car indicate the EGR valve is defective.
Can I just clean it out? Is there some diagnostic I can do instead of replacing it? (it's expensive). Do these valves stick, and need lubrication?
Dec 19, 2009 at 8:42 AM
  • 75,988 POSTS
Clean it out and passages, make sure its getting vacuum thru the modulator/VSV solenoid.
Dec 19, 2009 at 10:43 AM
