1994 Toyota Tercel Transmission Oil
120,000 MILES • 4 CYL • FWD • MANUAL
LSCOTTCLINE
I just repaired the CV Joints in my Tercel. Some fluid came out when I took the axles out. I am trying to find where to put the fluid back in at. Does anyone have an idea or a picture of where? I was told it was on the bottom of the transmission, but I cannot seem to find where. Am I looking for a bolt to take out or what? Also, when I find it, do I need a special pump to put it in with?
Thanks,
Scott
Jan 28, 2008 at 2:09 AM
2CARPRO JACK
  • 11,533 POSTS
I cant find a pic in my software, but it should be a pipe plug a little higher than the axle seal.Usually located near the drain plug. Yes, you will need a pump to put fluid back in
Jan 28, 2008 at 7:24 AM
LSCOTTCLINE
I do not see the drain plug on the transmission either. Where would I find it? Does anyone have a Tercel that could take a picture so I could see where to fill it?
Thanks,
Scott
Jan 29, 2008 at 1:00 AM
