1994 Toyota Tercel Radiator Fan Switch
1994 TOYOTA TERCEL
SKIPPERDAN
  • 6 POSTS
Engine Cooling problem
1994 Toyota Tercel 4 cyl Front Wheel Drive Automatic
My Radiator fan is not coming on. I replace the fan relay which was a waste of money as it still didn't work. So I'm thinking that it is the Radiator Fan switch. With the key on I can unplug it and it runs I plug it back in and it stops. Does anyone know how to test the switch. It has only one wire and is located on the thermosat housing. Any input would be greatly appreciated. Thanks SkipperDan
Oct 21, 2009 at 4:02 PM
DOCFIXIT
  • 18,828 POSTS
Does car have AC? there is more than one fan relay. The gague temp sender is on thermostat housing the temp sensor is below Dist. That should ohm at 200-400 ohms at 180 deg. What color is wire ?
Oct 23, 2009 at 5:57 AM
SKIPPERDAN
  • 6 POSTS
[quote:415bf2050b="Docfixit"]Does car have AC? there is more than one fan relay. The gague temp sender is on thermostat housing the temp sensor is below Dist. That should ohm at 200-400 ohms at 180 deg. What color is wire ?[/quote:415bf2050b] Thanks for the info, But, I figuire it out. I took out the themo fan switch which is located where you said and in doing so I found that it was stuck in switch was stuck closed which grounds it to the engine to stop the fan from running, so after applying some heat and a little bumping here and there it started working again. Probably should replace it but it's working fine at the moment and I can always just unplug it and the fan will run until I do replace it. Thanks Again! SkipperDan :-)
Oct 23, 2009 at 3:54 PM
DOCFIXIT
  • 18,828 POSTS
Excellent skipperdan
Oct 24, 2009 at 5:27 AM
