1994 Toyota Tercel OIL LIGHT ON WHEN OPERATE IN AT NORMAL T
RAULTR1961
Engine Mechanical problem
1994 Toyota Tercel 4 cyl Front Wheel Drive Automatic 120.35 miles
I REBUILD THE ENGINE,I REPLASED THE OIL PUMP
AND OIL PERSSURE SENDER UNIT BUT WHEN ENGINE HAS NORMAL TEMPERATURE THE OIL LIGHT
COME ON ,I EAR NOISE FROM INSIDE OF VALVE COVER,TELL WHAT CAN BE,THANKYOU.
Sep 1, 2010 at 12:04 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-could be the engine bearings if not the oil pump pressure relief valve not closing
Sep 2, 2010 at 2:50 AM
