1994 Toyota Tercel Oil leak
1994 TOYOTA TERCEL
LILIA1984
Engine Mechanical problem
1994 Toyota Tercel 4 cyl
6 months ago I had my oil sensor replaced because my car was leaking a lot of oil. Since the repair, it leaked a little. But now it is leaking a small drop every 30 secondes. It is leaking from the passenger side front of the car. It is not leaking as bad as it was 6 months ago but it is still not good. What could be the problem now?
Jul 29, 2008 at 7:35 AM
KHLOW2008
  • 41,814 POSTS
Hi lilia1984,
Oil leaks at passenger side should be caused by the crankshaft or camshaft oil seals.
Jul 31, 2008 at 6:19 PM
