1994 Toyota Tercel Gear Shift Locks Up
117,000 MILES • 6 CYL • FWD • MANUAL
PHYLLIS BUCKLEY
Gear shift locks up and unable to change gears.
Erratic, but getting worse. When attempting to change from one gear to another, the gear shift locks up and will not go into another gear.
I shut off the car and the gear shift works OK.
Start the car, and the problem continues.
Dec 16, 2009 at 4:17 AM
KHLOW2008
  • 41,812 POSTS
Hi Phyllis,
The clutch is either too low or it is failing causing the clutch disc not to be disengaged when the clutch pedal is depressed.
If the pedal feels low, it could be the fault of the clutch hydraulic system
You would need to get it checked and repaired in order to prevent being stranded.
Dec 16, 2009 at 5:35 AM
