1994 Toyota Tercel engine blower motor
105,000 MILES • 4 CYL • FWD • AUTOMATIC
GUILLERMO
I want tio know why the engine cooling blower stay
on always.
Jun 22, 2008 at 4:17 AM
BLACKOP555
  • 10,386 POSTS
chances are its a faulty coolant temperature switch reading too hot of a temperature causing the cooling fans to kick on and run!
if the guage is still showing cold and the fans are on the switch could still be bad as it has differnt wirings.
Jun 22, 2008 at 6:36 AM
KHLOW2008
  • 41,812 POSTS
Hi guillermo,
Ground the fan thermo switch wire and if the motor still runs, the relay is sticking. Replace the relay.
Jun 22, 2008 at 6:51 AM
