1994 Toyota Tercel clutch
ELLIEME
Transmission problem
1994 Toyota Tercel Front Wheel Drive Manual
I have been driving my car for a while and i have never come accross this problem before. When i was shifting into gear i would push the clutch down all the way and there was no resistance at all and i coulndn't shift into gear. I ended up having to pump the clutch to get some resistance so i could shift. I'm just wondering what to expect from a mechanic, i want to make sure they won't be charging me something that i don't need.
ps I checked the clutch fluid reservoir and it seemed full.
Mar 19, 2009 at 2:33 PM
  • 75,988 POSTS
Replace the clutch master cylinder bleed it and then bleed at the clutch slave.
Mar 19, 2009 at 5:16 PM
