1994 Toyota Tercel AC/Heater Fan Switch
1994 TOYOTA TERCEL
85,000 MILES • 4 CYL • FWD • AUTOMATIC
HOSP550
The fan switch is sending to the AC compressor (the AC light comes on and you can hear the compressor cut in), but the fan itself will not run in any of the switch positions.
I can hear a "click" from the passenger side kick-panel when the switch is engaged.
I have checked the fuses and they seem OK.
What's next?
Apr 29, 2009 at 9:31 PM
Could be the blower motor itself or the heater relay check and test then report back with some results
Apr 29, 2009 at 9:49 PM
