1994 toyota tercel
1994 TOYOTA TERCEL
BARRYG25
Hello Bob and ken, My question is this? I have jsut purchased a 1994 toyota tercel that is in fairly good shape. Rebuilt engine with about 25k on it new tires . interior is bad but engine is clean and runs well. My only convern is that when i travel over any kind of bump i get a metllic sound from the area of drivers front wheel/ i was told this could have somehting to do with a stabilizing bar or something like that? Is that something i should get taken care of immediately or is this indictive of other possible problems?
Jul 31, 2006 at 6:38 PM
GLENERIK
  • 5 POSTS
I dont think the tercel has a stabilizing bar. Check the two bolts and one nut that hold the hub in place. Remove the wheel, the bolts will be under the hub. I forgot to tighten those once and on the way home they would make like a "crack" noise when I would go over the slightest bump.
Aug 28, 2006 at 5:55 PM
