1994 Toyota Tercel
JAYE WALL
  • 1994 TOYOTA TERCEL
Engine Mechanical problem
1994 Toyota Tercel 4 cyl Front Wheel Drive Manual
This car is great, but I had the water pump replaced and the battery light and brake light stays on, on the dash.I chacked them both and nothings wrong that I can see. Do you know what it may be?
Sunday, November 7th, 2010 AT 6:29 AM
KHLOW2008
  • 41,814 POSTS
Hi jaye wall,
Have you tsted the alternator?
Sunday, November 7th, 2010 AT 6:35 AM
JAYE WALL
Yes tested it and was fine.
Sunday, November 7th, 2010 AT 6:42 AM
KHLOW2008
  • 41,814 POSTS
Unplug alternator wire connector and turn igntion on. If light goes away and comes back on when the connector is plugged, the alternator voltage regulator is faulty.
Sunday, November 7th, 2010 AT 7:06 AM
