1993 Toyota Tercel Squeal on Startup
1993 TOYOTA TERCEL
124,500 MILES • 4 CYL • FWD • MANUAL
BCGOBRAVES
My '93 Tercel (1.5L, 4-speed manual) has started making a squealing noise on startup. It'll last for 5-15 seconds and seems to go away faster if I put the stick in neutral rather than try to start driving. It also will usually not squeal at all if the car has been sitting for less than 6 hours or so. Otherwise the car runs amazingly.
Current mileage ~124500
Timing belt, drive belt changed ~110000
Oil/filter changed ~120500 (Using Mobil1 10w30)
Problem started around 123000
Jul 6, 2008 at 1:49 PM
MERLIN2021
  • 17,250 POSTS
Have the belts looked at, you described a worn fan belt, which will squeal...
Jul 6, 2008 at 1:53 PM
