1993 Toyota Tercel remove engine without transaxle
184,000 MILES • 4 CYL • 2WD • MANUAL
AL2494
How do you remove the engine on a 93 tercel without the transaxle attached?? There doesn't seem to be enough room between the front of the engine and the car frame to slide out the engine.
Jan 22, 2009 at 2:18 AM
DOCFIXIT
  • 18,828 POSTS
They are removed together if you need how to inst. click on site at bottom of reply ie. manuals. And for $9.95 you will get all the 411 you will need.
Jan 24, 2009 at 4:01 AM
