1993 Toyota Tercel Radiator fan
1993 TOYOTA TERCEL
150,000 MILES • 4 CYL • FWD • MANUAL
EPIFANIO TORRES
The fan stopped rotating. How do I troubleshoot to see if its a fuse, or the motor?
May 9, 2008 at 11:13 AM
Try direct power from the battery-disconnect the fan motor connector-blue and black is the power and white and black is ground-
Could also be a relay or water temperature switch
May 15, 2008 at 5:28 PM
