1993 Toyota Tercel loud engine
1993 TOYOTA TERCEL
20,700 MILES • 4 CYL • 2WD • AUTOMATIC
PAULAANN15
when my car is in park the car is very loud.
Sep 19, 2010 at 3:06 AM
KHLOW2008
  • 41,814 POSTS
Hi paulaann15,
Thank you for the donation.
Where is the noise coming from?
What type of noise are you getting?
Does the noise go away if the shift lever is moved to R, N or D?
Sep 19, 2010 at 5:23 AM
PAULAANN15
It sounds like it's coming from the engine. It's not as bad whenI take it out of park. Once I start driving for a bit it sounds okay until I put it in park again.
Sep 19, 2010 at 6:06 AM
KHLOW2008
  • 41,814 POSTS
Seems the problem is from the transmission.
With vehicle on slight gradient, shift to park and release the handbrakes. If vehicle starts to slide forward, it means the transmission parking gears are bad.
Sep 19, 2010 at 6:24 AM
