1993 Toyota Tercel eng idel
1993 TOYOTA TERCEL
200,000 MILES • 4 CYL • 2WD • MANUAL
CEROTAN
eng revs up & down continuosuly.
Nov 14, 2009 at 5:28 AM
4SKIN
your tercel has a idle speed motor it is under throtlebodythat has gone bad some times you can take um apart clean it put it back on and run it the prob is carbon build up plugs it up so motor jumps back and forth from high idle cold start to warm idle.
Dec 13, 2009 at 2:16 AM
