1992 Toyota Tercel Engine over heating but not when heater
14,000 MILES • 4 CYL • 2WD • MANUAL
MOCKAN
I am puzzled. When driving along the radiator hose to the engine seems to stay cool, and the radiator hose from the engine to radiator gets very hot. Maybe water pump out? But when I turn on the heater inside car the engine temperature drops, that means the heater core is acting like a radiator and cooling the engine. So the water pump must be working and is pumping fluid through the heater core. How can the hose from the radiator to the engine be cool, but the engine overheats? The cool water should be cooling the engine.
Can the thermostat be stuck closed? Then the water pump could be working, the core of the heater might still have some fluid going through it, but there might not be enough flow through the stuck thermostat to really get the radiator working to cool the engine?
Can someone please put this data together and arrive at the best answer? I can replace the thermostat, but other problems would cost hundreds of dollars and might not be worth fixing the car.
Jan 1, 2010 at 7:19 AM
  • 75,988 POSTS
Why don't you replace the thermostat don't work check the radiator if its clogged-up and the water pump if its doing its job
Jan 1, 2010 at 7:29 AM
