1992 Toyota Tercel 1992 toyota tercel 1.5 motor low commpr
1992 TOYOTA TERCEL
RICH FULTON
1992 Toyota Tercel 177896 miles
i have a 1992 toyota tercel with a 1.5 motor..motor was replace a bout 30,000 miles a go ..# 1 cyl is 100..#2 is 50..#3 is 140. #4 is 120 ... i aslo done a wet down test and was no change in the cly .... ... i was told it might be a head gasget ... or could it be a burt vavle ... thanks ...note car still runs and drive ...not very good gas milage ... thanks again
Nov 22, 2008 at 3:12 AM
JAMES W.
  • 2,394 POSTS
Sounds like burned valves. If it were a headgasket, # compression on #1 and #2 cylinders would be closer to the same reading. To repair either problem, the head would still have to come off. Hope this helps.
Nov 22, 2008 at 8:00 AM
