1991 Toyota Tercel transmission fluid
1REYMAR
1991 Toyota Tercel 4 cyl Manual 110000 miles
where do i check the trany fluid and add if needed?
Apr 18, 2010 at 5:46 PM
  • 31,937 POSTS
Hi there,
The transmission has it's own dip stick, it is located to the front of the transmission, it should be check hot and with the engine running, the level should not be over the HOT mark, if needed use Dextron 11 or 111 trans oil, cycle the transmission through the gears before re checking after adding any oil, if the old oil is dark and smells burnt, get the trans serviced.
mark (mhpautos)
Apr 19, 2010 at 1:16 AM
