timing belt replacement
200,548 MILES • 4 CYL • 2WD • AUTOMATIC
CASTANEDASAUTOREPAIR
the car arrived with a broken timing belt,and we properly replaced timing belt, my question is if the pistons could hit the valves when the timing belt is broken?
Mar 31, 2009 at 9:20 AM
  • 75,988 POSTS
Here is a guide to help you get the job done
https://www.2carpros.com/diagrams/toyota/tercel/1991
It is not an interference engine so you are safe.
Cheers
Mar 31, 2009 at 9:56 AM
