1991 Toyota Tercel Low beams wont work high beams do
1991 TOYOTA TERCEL
70,000 MILES • 4 CYL • FWD • AUTOMATIC
MSN1956
  • 6 POSTS
Hi hoe someone can help - (dont have much hair left to pull put)
I have high beams but no low beams. Running lights come on but low beams wont when i pull the lever back high beams come on.
All fuse are ok. I figured it was the swithc so I put in a new one - no luck. I have checked the bulbs and have continuity on each of the end leads
What else can it be ???
Apr 3, 2010 at 6:27 AM
Could be the headlight control relay behind center console or the headlight switch itself
Apr 3, 2010 at 6:36 AM
MSN1956
  • 6 POSTS
Thanks for your reply really appreciate it
The headlight switch ? - is that the one i replaced in the steering column or is elsewhere?
Also where is the headlight control relay ? by center console is that under the steering wheel ??
Apr 3, 2010 at 4:20 PM
Headlight relay:
https://images.2carpros.com/forum/automotive_pictures/12900_head_6.jpg
Apr 4, 2010 at 9:11 AM
MSN1956
  • 6 POSTS
I tore the glove compartment out so I could access the center console and I think I see the relay as per your diagram. I ma going to buy a relay and then just serach for one that looks like it :))
thanks
Apr 4, 2010 at 12:01 PM
MSN1956
  • 6 POSTS
Hi I pulled the relay out from under the console and it is the "circuit opening relay " so I guess thats not it
There is a relay under the glove compartment but that deosnt loook like it in the diagram
any other ideas as to wher it is
1991 toyota tercel automatic 2 door
Apr 5, 2010 at 2:32 AM
