1991 Toyota Tercel Low Beam Lights don't work
1991 TOYOTA TERCEL
100,000 MILES • 4 CYL • FWD • MANUAL
SNOWMOSLED
Hello, I have a 93 tercel and the LOW beams won't work. The high beams are fine. Checked the fuses and they are OK. Someone told me it is the switch in the steering column. The arm the turns on/off the turn signals and headlights I guess.
Anyone know anything about this?
How easy is it to replace?
Thanks in advance
Mar 6, 2008 at 5:08 AM
FISHERMAN
  • 937 POSTS
[quote:e2effc5f65="snowmosled"]Electrical problem
1991 Toyota Tercel 4 cyl Front Wheel Drive Manual 100000 miles
Thanks in advance[/quote:e2effc5f65]
Hello !!
Yes, its possible that the steering column switch its not longer good, first check if you "hear" a "click" whenever you actuate the switch, to replace the switch you have to remove the steering wheel (be sure that you have a puller to remove it) then make some drawings on the screws and pieces you are removing to put everythingt back in the same order..
Good Luck!
Mar 6, 2008 at 5:13 AM
SNOWMOSLED
I do hear a click. I don't have a puller, should I take it to the shop or are the pullers available at retail stores
Thanks
-Mark
Mar 6, 2008 at 5:25 AM
FISHERMAN
  • 937 POSTS
[quote:cc25feaaef="snowmosled"]I do hear a click. I don't have a puller, should I take it to the shop or are the pullers available at retail stores
Thanks
-Mark
Hello Mark !
Well some autoparts rent tools for free, (like autozone) but first remove the connector from the headlight and test if there`s power on the low beam mode, could be that both low beam filaments got bad at the same time (could be possible !) do that with a 12 volt tester (you can buy that on any 99 cents store !
let us know on your findings and good luck!1
best regards!
'[/quote:cc25feaaef]
Mar 6, 2008 at 6:17 AM
SNOWMOSLED
I'll give it a try..... A lot cheaper than the alternative.
Thanks!
Mar 6, 2008 at 6:27 AM
FISHERMAN
  • 937 POSTS
Hey Mark !! the name of the switch its just a headlight switch, here`s the schematic of it:
https://images.2carpros.com/forum/automotive_pictures/576_aaa_1.jpg
Good Luck!
Mar 6, 2008 at 1:57 PM
SNOWMOSLED
Thanks!
Mar 7, 2008 at 4:21 AM
MSN1956
  • 6 POSTS
mY HIGH BEAMS WORK BUT THE LOW BEAMS DONT - RUNNING LIGHTS ARE FINE - CHECKED FUSES, REPLACED SWITCH ON STERRING COLUMN AND CHECKED THE ACTUAL LIGHTS THEMSELVES - WIRING LOOKS OK . iS THERE A REALY SOMEWHERE ? i CANT FIND ONE
Apr 4, 2010 at 2:50 AM
