1991 Toyota Tercel LEAKING OIL
1991 TOYOTA TERCEL
221,000 MILES • 4 CYL • FWD • MANUAL
NCBADBOY
i noticed that the pulley where the alternator goes and the timing belt cover is the pully has cut a hole mit the cover should oil be coming out all under the car
Mar 19, 2010 at 7:28 PM
KHLOW2008
  • 41,814 POSTS
Hi ncbadboy,
The timing belt cover is only for protecting the timing belt from external contaminations.
Oil is prevented from leaking from the engine by an seal inside the cover, behind the timing belt sprocket.
If any oil is leaking, then yuo need to check the oil seal.
Mar 20, 2010 at 3:51 PM
