1990 Toyota Tercel WONT START-ROUGH IDLING PRIOR TO THAT
1990 TOYOTA TERCEL
197,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIGGEDY
FOUND THAT # 1 CYLINDER WAS ARCING TO CHASSIS GROUNG AND REPLACED CAP,ROTOR AND WIRES. AFTER CHECING FOR GOOD SPARK,DID A COPRESSION CHECK AND FOUND ONLY ONE CYLINDER WAS INCONSISTANT WITH IN TOLERANCES 110,160,170 AND 150 RESPECTIVELY CYLINDERS 1 THRU 4.
IS TIMING THE NEXT BEST AREA TO INSPECT???
Apr 23, 2009 at 5:12 AM
BMRFIXIT
  • 19,053 POSTS
Timing will effect all cylinders
next step wet compression test
and a cylinder leak test suspect rings
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 3, 2009 at 10:53 PM
