1990 Toyota Tercel water pump replacement
91,000 MILES • 4 CYL • FWD • AUTOMATIC
TW1984
Can the water pump be replaced without replacing the timing chain? I think the upper timing chain cover has to be removed but I am not sure about the chain. Thanks.
Apr 18, 2010 at 6:13 PM
  • 31,937 POSTS
Hi there,
This is a belt driven engine, the belt will have to be removed to fit a pump, as a new belt is very cheap, i would advise that you replace the belt at the same time.
mark (mhpautos)
Apr 19, 2010 at 1:21 AM
