1990 Toyota Tercel catalytic converter
1990 TOYOTA TERCEL
126,000 MILES • 4 CYL • FWD • MANUAL
ADANMAGANA
I have a 1990 Toyota Tercel and when i turn it on to get it warmed up, the catalytic converter turns red, and its hot. what would the problem be?
Dec 16, 2007 at 2:37 PM
Have the exhaust system check for restriction-
May be an exhaust leak before the catalityc converter, check for a cracked exhaust manifold.
There may be an engine problem causing it to run way too lean, possibly a misfire.
The engine may be running too rich and in combination with an exhaust leak cause combustion to take place in the exhaust pipe.
Dec 16, 2007 at 3:02 PM
