1989 Toyota Tercel valve seal replace
1989 TOYOTA TERCEL
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
RIGGLE
my '89 tercel 125,000 mi. was running rough while idling only. i performed a compression test and found #4 cyl. low compression, burnt exhaust valve. so i pulled the head replaced all 4 exhaust valves , and all valve seals, even intake valve seals. i lapped in exhaust valves, replaced intake valves in original positions. new head gasket of course, torqued head to specs as stated in manual. car starts and runs smooth but very extreme amount of white smoke from exhaust as if car was in fire and will not stop smoking. pulled head back off took to toyota shop to have inspected,head checked out good. put back on with new head gasket same thing. what would be causing severe white smoke. not losing coolant.
Feb 17, 2008 at 1:44 PM
LEGITIMATE007
  • 5,121 POSTS
how long since you first started the car, has this been going on?
Mar 1, 2008 at 1:57 PM
RIGGLE
car can run for 20 to 30 minutes
Mar 3, 2008 at 9:24 AM
LEGITIMATE007
  • 5,121 POSTS
how about brake fluid
Mar 4, 2008 at 6:44 PM
