1987 Toyota Tercel wont shift
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEROD47
  • 14 POSTS
need help please after removing trans for differential problem decideto rebuilt trans for high miliage trans was fine just wanted to put new clutches and seals in it now it wont shift it goes into drive & reverse but wont shift check governor ok check bearing location ok 6 ball bearings in it valve body vale ther is movement wat am i missing ty trans a55 2w drive
Sep 24, 2009 at 12:49 AM
JOEROD47
  • 14 POSTS
[quote:4e9bb031b0="joerod47"]Transmission problem
1987 Toyota Tercel 4 cyl Two Wheel Drive Automatic 160000 miles
need help please after removing trans for differential problem decideto rebuilt trans for high miliage trans was fine just wanted to put new clutches and seals in it now it wont shift it goes into drive & reverse but wont shift check governor ok check bearing location ok 6 ball bearings in it valve body vale ther is movement wat am i missing ty trans a55 2w drive[/quote:4e9bb031b0]when it shifts feel like it is going into reverse ty
Sep 24, 2009 at 4:02 AM
