1987 Toyota Tercel stalling
SAMEOLE
  • 1987 TOYOTA TERCEL
Other Category problem
1987 Toyota Tercel Engine Size unknown Wheel Drive Type unknown Automatic 149000 miles
when I start the car, it runs rough, I have to let it run a while until it sounds like it won't stall. If I try to put it into drive and drive away, it stalls. What causes this
Tuesday, February 19th, 2008 AT 4:06 PM
BLACKOP555
  • 10,371 POSTS
So your saying it goes away when its warmed up?
Does it do it only when the engien is cold and outside air is cold? Does it do it when the engine is warm and cold outside air?
Does it do it when engien is cold and ouside air is warm 60+
does it do it when engine is warm and outside air is warM?
Tuesday, February 19th, 2008 AT 8:36 PM
SAMEOLE
I just got the car, I was told that it didn't like cold. I'm in vegas so it's not realcold out. Everytime I start weather doesn't matter, I have to let it warm up efore driving or it will stall. It run rough. You can hear it smooth out and then it'll be ok to drive. This happens I belive in all kinds of weather
thank you
Wednesday, February 20th, 2008 AT 10:08 AM
BLACKOP555
  • 10,371 POSTS
First change the coolant temperature sensor and test the pressure of the pump and change the fuel filter.
Wednesday, February 20th, 2008 AT 8:30 PM
SAMEOLE
I believe the fule filter was changed, alot of repairs were made, also new exhaust. Could it be the choke or the carb?
Wednesday, February 20th, 2008 AT 11:16 PM
BLACKOP555
  • 10,371 POSTS
OOOO its carbed? I had a 87 like yours and it was electronic.
Yeah if its carbed make sure the choke is down on it before starting it, push it down by hand.
Thursday, February 21st, 2008 AT 7:17 AM
SAMEOLE
Ok-I will try that-thanks
Thursday, February 21st, 2008 AT 10:05 AM
