1987 Toyota Tercel high idle/sputters when shut off
1987 TOYOTA TERCEL
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
CODEENF2
This vehicle starts well, has a high ilde that does not level off when warmed up, then when it is shut off it sputters until it finally shuts off. I did not realize that a donation would be asked for. i will donate when I use this service again. I am unemployed (9 months)and very short on cash.
Jan 27, 2010 at 4:24 PM
Is this Toy a carb or an EFI original fuel system?
Jan 27, 2010 at 7:48 PM
CODEENF2
[quote:85727954d2="rasmataz"]Is this Toy a carb or an EFI original fuel system?[/quote:85727954d2]
It is a carb
Jan 28, 2010 at 2:13 AM
You need to adjust the automatic choke/fast idle-sounds like the choke plate is not fully opening causing the idle to go high
Jan 28, 2010 at 5:23 AM
CODEENF2
[quote:7149d89059="rasmataz"]You need to adjust the automatic choke/fast idle-sounds like the choke plate is not fully opening causing the idle to go high[/quote:7149d89059]
WHERE IS THE AUTO-CHOKE LOCATED AND WHAT IS THE ISSUE WITH THE SPUTTERING WHEN i SHUT THE VEHICLE OFF
THANK YOU SO MUCH FOR YOUR ASSISTANCE
Jan 28, 2010 at 5:31 AM
The choke plate is the butterfly its link to the auto-choke and fast idle-you need a repair manual to set it right or you can try spraying carb cleaner on all the linkages of the carb-sputtering-its bcuz the throttle plate is not fully closed
Jan 28, 2010 at 5:44 AM
